Jakob
- 5
- 18
- Louisville, KY
Well, I just picked up the M35 that I won off of EBay. It's a 69 winch truck, troop bed w/ the non-turbo engine. I went down with some knowledge gathered from here and a buddy to drive it back 385 miles on a prayer, haha. I encountered some troubles along the way and need some input.
How bad can overheating the engine to about 240 degress be? The PO had the wrong main belts on the truck and about 40 miles into the trip, they busted and I didn't notice until the temp shot up.
The clutch adjustment is about 1.5", which should be in tolerance. The clutch was great until we made a quick stop about 30 miles away from home. I hadn't had a problem out of it the entire trip and this includes climbing some long mountain stretches. I can pinpoint this one stop where the clutch immediately started slipping.
It's not to the point where I couldn't drive the truck, but if I went over maybe 75% throttle, it'd break loose and slip BAD. However, if I didn't load it too much and the ground was flat, it'd still drive at 45mph without slipping at all (based on mph versus rpm). I tried (feebly) searching, but all I can pull up is the adjustment information here.
The blinkers also quit working about the same time. The green light on the column flashed the whole time before, along w/ the signals. After that stop sometime, they quit flashing and would just go on steady. I'm assuming the flasher relay just needs replacing?
Overall the truck was well worth the money. The cover for the bed needs replacing and there's a fair amount of rust, but nothing I can't fix. The paint NEEDS to be redone, it was brushed on way too thick and it's a standard green, not OD. One of the tires is missing the tube (rear axle inner), but the rest held up well. I think they've been replacd though, the tires are Goodyears and even though the speedo was reading 52-53 mph (at about 2500rpm), my chaser said it was actually running about 60mph.
Also, I have NO idea how to work the wipers or winch... any help? I've been cruising the manuals when I can, but I just haven't found the ones I need yet.
