New deuce owner
Dunkeye11
Fairfax, Virginia
so finally got a chance to clean up and go through parts of my truck I hadn’t before. The truck is kinda odd has its Tach bellow the dash etc previous owner told me it was a 50s truck converted to Multifuel but has 67 data tags
My questions lay lay in the engine bay I’ll post pics when I get the chance. But I have a lot of disconnected fittings floating around I can’t tell if the fuel filters have been bypassed because when I went to drain them nothing came out.... i have a regular 24v electric horn mounted in the grill not plugged in regular air horn works. Alternator cabling bundle runs across the center of the engine idk if it was a convert from the 25 amp to 60 amp
other things I have a strange air valve fitting in the cab passenger side not connected to anything. A switch on the right of the gauge cluster with no label. And a few other oddities.
ZiggyO
437
Nebraska
If it has the lower dash bracket for the tach, it was indeed a gasser that was converted......
Z
Another Ahab
4,489
Alexandria, VA
Your third post.
Did you ever receive any welcomes?
For record, here's a welcome to you from just down the "street" here in Alexandria VA .
