New Deuce, things I had to do.........
martinwcox
Wilmington, MA
Only had the Deuce for a few weeks but have been busy sorting out a few issues and general PM work.
1. Had the 11.00 X 20 XL's mounted on the rear axels
2. Had quite a few loose fasteners on the axels, torque back to spec.
3. Found missing clutch inspection cover, will be making one from a new gasket as the pattern.
4. Converted primary fuel filter to spin-on, rest already done, new filters for all.
5. Changed oil.
6. Remove 5-ton air cleaner assembly (not plumbed in), replaced with regular mushroom type on existing standard air cleaner. Replaced filter element.
7. Replaced windshields, wiper motors and ordered wiper upgrade kits.
8. Purchased a full set of seals and gaskets for all axels, have a leak to fix.
9. Replaced blown sealed beam.
10. Replaced battery, snow storm and freezing temperatures killed one.
11. Purchased a few contingency spares, air compressor, in-tank fuel pump and starter relay (existing is looking very sad.)
Nothing too expensive or difficult but an example of what needs to be done once you get that baby home.
cattlerepairman
3,278
NORTH (Canada)
I hear you...the initial work to get a new-to-you truck up to snuff is a lot of small things that simply need to be done. After that, the upkeep is not so bad anymore. Just try not to break stuff! :)
