new for me 1985 M1010
black_wolfnhn
stevens Point Wisconsin
just got a m1010 it's got some issues one of which is that the lower alt is junk and the upper alt doesn't seem to be putting out enough power either, it has a pair of Leece Neville 4629JA alternators but apparently they are no longer made and was wondering if anyone here knows of a good replacement that would essentially be a plug and play.
black_wolfnhn
do you have part numbers for the delco ones that would work the best?
Also the Leece Neville alternators are both 24 volt 100 amp, and everything else for the 24 volt system is still fine and intact so I would prefer keeping it 24 volt.
NDT
7,421
Camp Wood/LC, TX
What are your plans for the truck? If you are looking for reliability for daily use and long distance camping trips, suggest you swap over to a serpentine system from a 6.5 Chevy pickup. If you are prepared to deal with that Duvac smoke generator, stay stock.
black_wolfnhn
from my own personal experience I would rather keep a mutli v belt set up due to the redundancy with the multiple belts, it's saved me from having to do roadside fixes on several occasions, the problem I have is that the 4629ja alternator is apparently discontinued soi I'm trying to find a more readily available replacment.
