New from TX with 5 ton M925 driving home
3poffroad
Cypress, tx
Hey guys, just bought my first 5 ton from GovPlanet. It's a 1984 M925 with the big NA motor and duals. I'm picking it up Wednesday. It shows to run and drive and I feel I got it cheap. 4 grand. I have to drive this thing home. 200 miles. Already have insurance on it, and I have my class a CDL. Anything to look for before I make the trek? I'm new to this. But not new to diesels or mechanical. I own an off-road shop here in Houston.
Just mainly looking for advice or "to dos" before driving it home.
I look forward to this new hobby and learning everything I can!
Plane Fast
Panama city FL
The truck looks good.(needs a bath) The only thing I see so far, is the top will not make the trip with out securing the leading edge. For some reason the gas peddle looks flat. (No travel) Could just be the camera angle.
As always check all the fluids (diff, tran, engine,..etc.) I would bring two batteries to be on the safe side. (The truck has something about jumpstart written over the GP sticker.
Plane Fast
Panama city FL
I would live at 55 or less, and check the brakes extra good!
You may want to get a replacement mirror as well for the broken ones. It's hard enough to see with good ones.
m715mike
3,823
Montgomery, Texas
Howdy from just north of Cypress, Texas.
Good luck on the recovery. Keep us posted on the progress.
I saw that two.fiveM35 shared a link for the upcoming Texas Rally on April 1st. That weekend is always a good time. I hope you are able to make it and bring your new truck.
Scar59
41
Mt. Eden, KY
What's about the top (safe) speed of this truck? I'm taking back roads back home till I get accustomed to.driving it
I have the same truck. Check all the engine fluids, lights, and ensure the air system (primary/secondary) stay pressurized
and recover after braking. Test the brakes a lot before rolling home. Fill the tank with fresh diesel, add Power Service Diesel Klean. Drain water separator in left front fender well. Bring the front tire up to 90 psi. keep the back at 70psi.
It will cruise at 58 -60 mph easy. Take the highway, it needs a good hot run. Watch over pass expansion joints, let off before them or the rears will want to bounce around. (no weight on them). Run with your lights on. Take pictures and a credit card. NHC 250s love to run. When you get it home change the engine oil, and fluids in the transfer and diffs.
I have the spin on oil filter adapter kit listed in the classifieds, a must for future filter changes. Be safe, have fun.
