new guy M47 no spark???
Pipefighter
Im new to the site and first wanted to say hellow to everyone. I just bought a 52 gasser [w/continental I believe] that Im trying to get running. The dist looks like a magneto type W/wires threaded onto sparkplugs and is getting power but not putting out spark.
Thanks in advance for any help you can lend.
1,806
CHeck yer coil. I had a 52 M275 tractor and replaced points, condenser and all that suff to no avail. Coil was the problem.
Pipefighter
recovery- the dist and coil are one piece, some kind of mechanical or magneto type. It has one hot wire feeding it.I dont know what it is yet and didnt want to take it apart till I learn more about it.
1,806
Once you take the cap off (it unbolts) you can see the actual coil slid in there. It sits right beside everything else. It also has an oring under it. Mine was frozen stiff in there. My saving grace was GM heatvalve lubricant spray. It was the only thing that got it freed up.
Pipefighter
Thanks maccus Ill get some manuals for it, alot of good info.
recovery-Whats the everything else the ciol sits next to?
points- cond ? Anything that should be serviced?
Ive got a hot lead running from the ign to the coil. It has a waterproff conection on the side of the dist.
1,806
Yeah, thats where the rotor, points and condenser sit. Don't fear thaking the top off, its gets you a much better understanding of what you have.
Pipefighter
Thanks recovery, I dont know what I was thinking.1952 has to have points.
Ill pull it apart, check points and test the coil.Ill post what it was soon as I find out.
