- 488
- 44
- 28
- Clayton, Illinois
Anybody have any problems with any of the new old stock led marker lights? I bought 6 new in the static wrap lights. I put 3 on my M817 without any problems and they work great. I didn't need any ground other then mounting bolts. Mounted the other 3 on my 929a2 and they worked for a few seconds and then 1 would quit working and then another. Had 24v at every light. Leave it on for a few minutes and one may come on for awhile then back off. Thought maybe it was a ground problem so I added a jumper from trailer plug ground on frame to mounting bolt on one of the lights and then added one from another hole in frame to mounting bolt. So I have the ground from the 2 mounting bolts holding the bracket on and 2 other separate grounds and they still don't work. I used dremel tool to clean all ground points along with electrical grease. All of my connections are soldered. I took all the lights back off and went directly to the battery and can only get one to work by hooking ground off battery to grounding strip on light but it doesn't always work. Anything I'm missing or did wrong? Possibly bad lights? Thanks!
