New m1009...no lights
thtrev2001
25
San Antonio, Tx
Picked up our first m1009 today, starts, runs great, no rust, great truck...except, no lights whatsoever. headlights, turn signals, brakes, nothing. Whats my first step, or even point me to the right section of the TM...will post pics tomorrow.
M813rc
3,208
Near Austin, Texas
This panel is directly to the left of your regular light switch. Make sure the right one is in the up position for the lights to work. In 'All Off' none of them will work. The toggle is spring loaded, you pull it out slightly to clear the lock, then flip it up. It is all explained in the -10 manual.
Cheers
405timothy
Seminole, Ok
made this mistake myself once, replaced swich, fuse, bulbs, and it turned out to be service light switch got move to blackout light position
Blood_of_Tyrants
11
Lebanon, TN
Like they said, the first step is to make sure your service light switch is on. After that check fuses. Then start looking for a bad Service Light switch or broken wires and connectors. A cheap multimeter will make troubleshooting much easier as you follow voltage.
Warthog
232
OKC, OK
The TM 9-2320-289-10 manual tells you how all the switches and idiot lights work.
thtrev2001
25
San Antonio, Tx
Thanks for the TM reference, and yes the blackout switch was sticking, I thought I had operated it correctly, but after playing with it for a minute it seemed to be a little corroded and loosened up and was able to get it working. Thanks for everyones help.
Anna Mull
Elmendorf, Texas
same scenario
same outcome
I make the service light switch (check) part of my pre-flight checklist, since my dogs have a habit of kicking it (off) on their way into the CUCV
