ballencd
- 78
- 28
- Columbus, NC
Just got a 1984 M1010. I drove a M1009 for 18 years as a DD but it has been sold for probably 8-10 years now so I am familiar with the CUCV vehicles but not polished up of late.
I have replaced the harmonic balancer due to age and cracked rubber, the flex plate due to several chewed up spots on the teeth, also pulled the glow plugs and found all 8 were toast so they were replaced too. With new batteries installed the lights didn't work.....none of them. I did inadvertently leave the headlight switch on when I stopped working that night and during the night they came on. I figure around 0500-0600 because the battery was not discharged much. They are working fine now....I am thinking the headlight switch cleared itself....??? I took the glow plug card out and used a shot of either to get it running the first time as it had not been in I think about 10 years. Hind sight I should have flushed the fuel system before I tried to start it but it did start and smoked a good bit for awhile. Since then I have drained the tank and put fresh fuel in and it starts and runs much better. Still not what I want but better. It has only run for an hour or so. The starter also stopped working when I was trying to figure out the flex plate issue and that has also been replaced with a good working unit.
To the problem.
After the flex plate and starter got reinstalled it started fine but now the low oil pressure light does not come on at all. Seems like all the other dash stuff is working but no light. The low coolant (yellow) light comes on and the dash lights work but that is all. I am not familiar with this dash compared to the M1009. The first few times I started it before I repairs the light did come on and go off as soon as it started. I looked at what I think is the oil pressure switch on the back of the drivers side head and it is connected.
I am not sure where to start on this. Fuse, power, light bulb…..Is there a good place to start or something that I overlooked?
ballencd
PS....I'm trying to get some pictures up here as I know you guys like pictures.
To the problem.
ballencd
