I have to work with what I ownYou would do better with a heavy duty truck hand code reader. Will plug right into the diag port.
Got that.Ok then you need a miltope laptop with the interactive manuals and the Dearborn protocol adapter to connect to the truck.
Pressure release valve on the side. Note that I have the newer model.Is the air dryer dumping out of the bottom expello valve or out of the pressure relief? Maybe you have an over pressure situation.
If it shows over pressure then what?I think you are over pressure on your air system. That may explain your other air issues. You can pull one of the tank drain cocks off and screw in a pressure gage see what’s going on.
the two gauges show about 95PSI I cleaned off the valve with some brake cleaner, and it seems to not blow by every second.Adjust the air governor down to around 125 psi. If the pressure relief valve on the lower side of the air dryer keeps popping off then you are over pressure. The more you rev the engine the more the compressor makes pressure. I think the safety is set to around 160psi. If that wasnt there you would blow a line off. The governor is on the compressor on the drivers side of the motor. Could be a bad governor.
I noticed the exact same thing today. I would push the master Power switch and after a few flashes on highway all 5 lights would flash. If I unplug the unit and plug back in. It would again flash highway for a second or 2 and then go into the 5 button routine.Your CTIS - when does the 5-flashing start? On mine, I'd hit the master switch on, and even without pressure or the truck running, my CTIS ECU would flash HWY 1-2 times, then all 5 would start flashing. I had a bad PCU transducer. Otherwise, 5-flashing could be a bunch of stuff. The pressure switch on the wet tank, could be disconnected or damaged wiring, could be the solenoids on the PCU. Check air pressure on the wet tank, then test the pressure switch coming off the wet tank. I tested mine from the canon plug in the cab after disconnecting it from the ECU. The Dana/Spicer manuals give wiring, find the pins that go to the switch and test from the cab in addition to directly at the switch.
Also, check out this thread: https://www.steelsoldiers.com/showthread.php?162326-LMTV-CTIS-Question
There's other threads that cover CTIS, including non-LMTVs (813a1?)
If your referring to the dash break pressure gauges that is just barely there at 95lb but even so that may still not indicate over-pressure is not occurring. It may show that any over-pressure release valve(s) are working. But they may be working too soon since 95 sounds a little low. Check it where Will/Suprman suggested to get a better idea of things.the two gauges show about 95PSI ...
