cruiseroftheland
- 3
- 3
- 100 Mile House, BC
Hello everyone,
I recently acquired a 1956 M-135 CDN.
For all those purists, you might want to look away, as this will not be a restoration
The engine and transmission were no longer original. It had a massive GMC V6, 432 cu.in. and some kind of GMC manual transmission, but they were never finished. It was not a running project, but overall it looked good. The previous owner passed away and lived up by Horsefly/Williams Lake area. He built the engine for the truck, so I'm hoping the rest of the components are in good condition (like brakes, wheel bearings, etc) if it warranted such investment.
Mine goal is significantly different. The body is ok, but missing a few things and has some dents. The box is in good condition. I will not be keeping the cab, so if anyone needs parts, let me know. I will keep the box, but not for the truck. I have a 4 yard, 3 way dump box (currently on my farm Dodge) and I have a different cab (1st gen Dodge D250 extra cab).
I live in a very rural area east of 100 Mile House, BC and need the truck for the property. I have a 1992 12V 5.9L Cummins in good condition out of my current farm truck. Since the M-135 has a divorced transfer case I will be doing a full swap and since I want to be able to have low gears still, I chose a commercial truck transmission with overdrive.
I was able to find a low kilometer Eaton Road Ranger RTO - 16908LL with an SAE #1 bellhousing (which I might have to change to an SAE #2)
The Eaton has a low, low gear of 14.56:1 and an overdrive of 0.74:1, so I should be able to go over 100km/hr on the highway while still having good crawl gears. It's massive . It's 2 feet wide by 3ft long and barely fits.
The plan is to strip the frame and start by locating the engine and transmission correctly, and once that is all fabricated, I'll be locating the cab. I will be transferring most of the M-135 controls for the PTO and transfer case to the new cab, as well as the information decals.
I'll need to find a different steering box that I can mount ahead of the front axle. I'll need to find a brake master that will work with the system, likely a hydroboost one from the limited research I've done. I will have on board air in the truck, and I might do that with a York compressor or an electric one. If anyone has suggestions, please let me know.
Once I have a chance to dig into the truck I'll be scouring the forum for part numbers for brake components, u-joints, bearings, etc.
Eventually the goal will be to put a small Hiab crane on it as well. This will be the main farm truck for getting firewood, moving dirt, towing, pulling a large hay/horse trailer, etc.
I live off grid and am slowly building up a homestead. I've been off-roading Land Cruiser trucks for over 20 years, so this will be a fun upgrade.
For those in Canada, to be able to drive this truck, did you need to get a Class 3 driver's license since it's tandem axle?
Mat
Mat
