New member multifuel oil filter adpator
CSA66
Franklin nc
Hello everyone I don't own an MV at this time but would like to own an m37. I was reading some of the older post about spin on oil filter adpator for the multifuel engines . I made a set for my brother that worked very well . If there is enough interest I would make more.
CSA66
Franklin nc
We need pics! And...for which filter numbers?
I will try to get pictures this weekend and filter number. The filter I used flows a little more than the canister filters . If there's a certain filter you want to use I can make the adapters for it . Thank you for your reply.
CSA66
Franklin nc
I apologize for not getting a picture uploaded last weekend . I was kind of under the weather. This is a set I started for a friend of my brother he was unable to take them. I still need to make the tubs and do a little more machining. The filter I used is a wix 51970 we chose this filter because it flows a little more than the original filters. I can make the adapters work with a different filter if I need to. I'm a car guy and I know our hobby has to take a back seat to other things so I'm not trying to get rich here . I will keep the cost as low as I can .
