New member with M1008 question
petekoloz
lecanto,fl
Hi to all from sunny fl-
I have a 1986 M1008 w/6.2 .
Can anyone advise me regarding the tee that is connected to the vacuum pump?
One barb appears to be left open, should it be capped?
joshuak
214
Slower shore, DE
Welcome to the site petekolz, check out the manuals for your truck found here.
In regards to your question, TM9-2320-289-20P or Unit maintenance and depot maintenance parts and special tool lists for CUCV, page 34 Figure 10, shows that the tee should be... capped.
Enjoy your vehicle!
petekoloz
lecanto,fl
Thanks to all for the helpful replies and the welcome.
@ Rick - my second purchase was twenty magnesium arches of the truck maintenance tent variety (of which I'm currently using 7 to form a 20'X48' tent ) and I think my next buy should be a wrecker.IMG_20150829_174145.jpg
Gripy
Los Angeles, CA
Yes it should be capped. Line from vac pump. then the line to the Vacuum regulator on the IP.
petekoloz
lecanto,fl
Thanks to all, after capping that barb the truck is shifting into 2nd at 25mph and into 3rd at 35mph. Much better. I've also found that I can force the shift a little sooner by backing off the accelerator momentarily when I'm nearing the shift speed, this makes for a much gentler shift.
I bought this truck in 2002 and it just turned the odometer over a few days ago. I recently erected a magnesium frame truck maintenance tent using 7 arches. I used 2 sets of 4 ft purlins that came with the arches and I fabricated 4 sets of 10ft purlins from fence pipe, welding 2inch washers to the ends bearing 7/16" bolts/nuts to fit the established method of attachment. Used vinyl billboard tarps make the cover:
20'W X 48'L X 14'H
Here's how I stretched the vinyl to eliminate water pockets along the peak:
petekoloz
lecanto,fl
Is your tranny shifting funny?
Yes it was, real hard and it would bark the tires going into 2nd and third...
Also, I'm battling a recurring case of front-end Death Wobble by replacing the Rancho stabilizer shock every 15k miles or so. One of these days I'm going to figure out how to double up on those things and maybe that will cure it.
