New MEP 803 Owner (So far very happy)
enem178
Jersey
I won an auction on Govplanet about a mouth ago for a 803a. It was just delivered today and so far I'm very happy. The unit indeed looks to have only 14hrs on it. I don't know how common it is, but it also came with the manuals and 2 red top batteries. Im sure the batteries are old but look to be unused. I have them on the charger now, we'll see if they hold a charge. The only area of concern that stands out right now is there looks to be some diesel residue around the injectors. I'll see what happens when I get it started. Hopefully it runs as good as it looks.
PS. I have no idea why some of the pix are sideways..
IMG_1064.jpgIMG_1065.jpgIMG_1066.jpgIMG_1069.jpgIMG_1071.jpgIMG_1072.jpgIMG_1077.jpgIMG_1086.jpgIMG_1079.jpg
Coug
4,626
Olympia/WA
definitely go through the 100 hour break in. Even if the gauge is wrong, you won't be hurting anything by doing it.
csheath
216
FL
Might as well go ahead and replace the dry rotted fuel return hose. I used Gates part number 27000 1/8" from Oreily auto parts and it's holding up good. If memory serves me correctly I bought 10 or 12 feet of 1/8" and a couple feet of part number 27002 1/4". The short 1/4" pump hoses can be replaced by cutting the crimped covers off and just pushing hose on. You can use spring clamps or fuel injection type band clamps if you want but I think they would be okay without clamps. You don't need the higher priced fuel injection hose. These are all low pressure hoses.
You have to pull the top off and the end cover by the fuel tank to replace all the hoses.
enem178
Jersey
Thank you for the detailed info! Are those the pump hoses near the injectors in the 7th pic?
Daybreak
2 Star Admiral
773
Va
Howdy,
Check out the sticky at the top of the Generator Forum
MEP-802A MEP-803A Filters and Parts
2nd post has quick links
3rd post has the manuals you need. At least on the computer. Always nice to have the manuals still in the plastic.
Yes, I would say your unit has 14 original hours on it.
IMHO
long drain the oil, replace all filters, long drain the fuel tank, replace all filters
add john deere break-in plus oil, new filters
replace all fuel filters, careful on the cup filter, make sure its in the little track with gasket all the way around.
You might have trouble getting the fuel/water filter off. It seems King Kong put it on dry.
replace all fuel return lines
Charge the RedTop batteries with a good AGM charger. They will come back to life.
Double check the Quad Winding fuse is in place.
Fresh diesel, turn to prime and run... and wait, it takes a while to fill up all the new fuel filters... wait some more, the unit are self priming to a degree, it will fill all the filters and then return back to the fuel tank.
Have all your equipment ready for starting.
set what voltage you want (behind control panel, 120/240 single phase) ,--only when not running
Have a multimeter ready to check the outlet, and lugs. (convenience outlets are 10amps only) if you trip it, the reset button is right inside the front control panel.
Look at keeping a good load o the unit for at least the first 100 hours with the break-in oil.
After that, a good 15w-40 diesel oil of your choosing.
good luck.:)
enem178
Jersey
Howdy,
IMHO
good luck.:)
I actually ordered the filters 5 mins ago thankls to your sticky! This is AWESOME info........ Greatly appreciated
csheath
216
FL
Yes
The small return hose will come off of the rail that has the 4 1/4" lines. It goes up to the injectors and connects to plastic tees then loops around and back to the tank. The 1/4" hoses may be okay but the small cloth covered hose doesn't last long and is most likely the cause of the fuel you see.
enem178
Jersey
Yes
Ok great, i'll get on it. Thank U
Light in the Dark
6,651
MA
Hopefully your canister drains clean, and you have no reason to remove. With that said, if you DO... save yourself time and effort and simply remove the upper side sheet metal panel next to it. It will allow you to get your filter wrench as high up on the canister as you can get, for maximum removal force. If you take it off, oil the seal on it (or the new unit) so you never have to fight such foolishness again.
enem178
Jersey
Words of wisdom.....Thx
Daybreak
2 Star Admiral
773
Va
Howdy,
Drain's clean?
Change it. It doesn't matter if it drains clean. It's a filter. Drain's clean means nothing to what's going on. The drain on the fuel/water separator filter is for draining water.
Light in the Dark
6,651
MA
In the units I have inspected after changing, they are in very decent shape considering the trash that can accumulate in them.
