poof
Dirty Hippie
- 568
- 19
- 18
- Wisconsin, Watertown
These are the only pics i have so far..
had it delivered to Wisconsin state line .. then drove it home 100 mile trip... 8.6 MPG.. sat for 2 years.... ran nice as far as I could tell...missing one upper tray for litters... am working on light in back.. the 3 way switch for B/O is toast.. need a new one, are they the same as all the others? 12v verses 24 v?..
bit of rust here and there.. not bad... will be painting in the 3 color pattern of the late 70,s and to mid 80's.. I have a couple old pictures of a pair of them in back ground, during a change of command cerimony band and all in my Germany days..
need to find a correct gas heater for back compartment also.. its missing..
I was shocked to find it has a 30 or so Gal tank... ( $98 ) owch!.. was thinking was a 20 gal tank..
has a exhaust leak on right side mmanifold.. worked the bolts loose already.. back lights are working on left side only .. break..turn signal.. and back up light... may be bulbs only.. left side wires are all buggered up.Need lense covers.. one each back up lights and red run light cover... and one black out marker for back.... to cold this week to mess with it all... its killing me... where would I find/ buy/copy a TM on the ambulance ? m886 spicific. back compartment wireing and lighting and heater stuff? 266-20 is the best or the -10 ? i have looked a bit at the files located here on SS .
Only reason i did this and cheeted on the m2 halftrack rehab, was this didnt seem to need a bunch of work to make road worthy..
Will have more pictures soon.
J.P.
J.P.
