is your motor knocking at all?
No I didn't.Pull your vac pump and prime the pump and oil system manually.
Did you prime the oil pump before or after you installed it?
Oil pan had a leak, so I changed the oil pump while I was in there. New Pump pick up tube was a press on.Did you replace/swap the pickup tube? Is it pressed or brazed on?
Is it at the correct height?
I'm guessing you changed your oil pump, but I only see it mentioned in the title.
Is it a new pump?
Why did you change it?
Help us out here.Finally got the pump to prime.
Thanks for the help and suggestions.
No problem.Help us out here.
How did you end up priming the pump? Steps for other people to follow.
I almost stopped reading (in disgust) at this point. You got me!Since I don't have a tach I'm unsure of the exact rpm the oil light finally turned off, but you'll have to trust me I reached the rpm limit of the 6.2.
