New owner m1009 but problems already
marbaja252
9
Polk City/Iowa
BOUGHT TRUCK E-BAY SCARY. RUST FREE m1009 , RUNS GREAT AND RUNS STRONG. AFTER DRIVING AWHILE 5-10 MIN HEAD LIGHTS, GAUGES, T/S BRAKES ALL OUT WOULD NOT TURN BACK ON. HAD TO DRIVE BACK QUICK ON FOG LIGHT OWNER ADDED.
DID ALL I KNOW WTIH THIS TRUCK BUT NO LIGHTS. HAVE GREAT m35A3 FOR 3 YEAR SO NOT NEW TO THE MV PROGRAM.
AFTER SITTING 10 MIN ALL WORKS AGIAN WHAT THE heck? STILL TEST DRIVING AND CLEANING OUT OLD OWNERS CRAPPY WIRING.
ANY EASY STUFF TO LOOK AT?
THANK GUYS
DREDnot
443
Phoenix, AZ
That's where my lighting issues were coming from.
Missing a jumper wire in the dangling blackout connectors.
PO(?) removed the B/O switches.
cucvrus
10,396
Jonestown Pennsylvania
30 amp fuse is loose in the fuse box. Common problem. Cleanup connections at fuse. I have removed the fuse block and cleaned it up and have had success. Some beyond that and need an in line fuse put in place. Actually 2 inline fuses are served from that leg in the fuse box. Good Luck. Sounds minor. common problem. Lots of help available.
M813rc
3,187
Near Austin, Texas
:ditto:
In my early days with CUCVs (which always seem to have electrical gremlins), I tended to start with the complex answers to questions, like swapping blackout light switches, etc.
Then I figured out the fuse box was the source of many of my problems, the most common being corroded or just plain loose fuse holders. One explanation for this might be someone adding an additional power tap at some point by shoving a spade connector in next to the fuse.
Check/clean all of those connectors, and pinch them a little closer together. Best to go ahead and replace old fuses with new ones (they're inexpensive!).
Once you've done that, if your problems persist, start the more complex troubleshooting.
Cheers
Tinstar
1,770
Edmond, Oklahoma
Definitely also look at whatever else was added to the factory wiring.
Who knows what else you’ll find to fix.
Warthog
232
OKC, OK
Also always use quality fuses. The cheap made in China versions they sell at Harbor Freight can cause issues.
Many of the common repair tips can be found in the Helpful Threads sticky at the top of the CUCV forum
MarcusOReallyus
816
Virginia
Excellent advice. [thumbzup]
marbaja252:
  1. Don't add anything to that fuse box. It's already badly under-designed.
  2. If someone else did, re-do it so that it's not putting a load on that fuse box. Figure out what was added, and how, and start a new thread. Some of us will walk you through removing the butchery and then doing it right.
  3. Read the stickies.
  4. Please STOP SHOUTING. It's rude to type in ALL CAPS.
M813rc
3,187
Near Austin, Texas
My understanding on those was that they often failed to burn out when the designated amperage was exceeded, so something further down the electrical line had to instead. That kinda negates the purpose of a fuse!
Cheers
