heres where i'm at so far. before i got it, complete brakes from master cylinder to shoes. gas tank cleaned and sealed, new gas lines to carb. carb still is a little stickie, soon to be replaced. all fluids replaced. new wiring harnes started, yet to be finished. if i had brake lites i would be on the road more.
i have lots of parts that i'm going through. i look in catilogs to try to figger out what they are. just found all the parts to mount spare on drivers door. a lot of details to take care of, like the manifold heat control valve. the shaft is there , leaks, with no nut or plate. i plan on taking one step at a time and go through everything untill its all corect mechanicaly then on to body.
also have lockout hubs and front disk breaks
