New Pictures of Oil Pump Suction/Pressure Line Plumbing
armytruckdiesel
We have installed a new relief springs and had new hoses made but need some help on installing the hoses. The hose on the bottom of the oil pan needs to go where on the oil pump? And the line that goes to the fitting on the side of the engine block needs to go where on the oil pump? Any pics/drawings would be helpful.
Thanks,
Andy
WillWagner
2,507
Monrovia, Ca.
RE: Cummins NHC 250
The hose from the top of the pan goes to the outer most port on the lube pump, the one from the bottom of the pan goes to the inboard port on the lube pump.
