new poster needs M105A2 info
Goldy
Columbus Ohio
I just bought a M105A2 and am trying to learn all about it. The trailer is amazing but every one who sees it tells me a different story. Many of my questions will be answered when the TM I ordered arrives but one thing I want to know is did these ever come with seats? If so is there a source? My knowledge is skimpy because I was a sailor and we didn't have many trailers on board. Any help would be appreciated.
Goldy
MWMULES
352
DESOTO, KANSAS
No seats, and most insurance companies wouldn't let you haul people in one,even in a parade. The manual is in our manual section forum and is free to down load.
Tracer
14,388
Hawthorne, NV.
DSCF1749.jpgGoldy I'll tell ya another story. As MWMULES stated, look up the TM for the M105A2 here, follow the TM, and do a PM on your trailer. If your trailer has one, pay special attention to the separation valve (picture). They can go bad internally and your brakes will perform poorly. It's an inconspicuous item that is easily overlooked. I assume you'll be pulling your trailer with an MV, so, hook up your trailer, turn on the air, and if you don't hear any air leaks, press down on your trucks brake pedal and then let off on the pedal. You should hear a noise similar to a baby crying. That means your separation valve is working, and probably your brakes as well. I had poor braking performance after I rebuilt my trailers brakes. So I used this test to check my separation valve, and the separation valve was quiet. I replaced my separation valve, and now it cries like a baby, and my brakes work. Hope this helps, and good luck with your new trailer.
tobyS
840
IN
Many of the 105s have been handled with a fork truck and the above actuator breaks at the pipe thread to the tank. MWMules answered about seats. Note the tires are not rated for today's highway speeds, but if your pulling with a mil vehicle...neither are most of them.
Valence
565
Davis County, UT
Hey Goldy, welcome to the site and hobby!
Here's a helpful thread for when you tear into the hubs to replace seals, grease the bearings, and check the brakes:
https://www.steelsoldiers.com/showt...spindle-size&p=1881487&viewfull=1#post1881487
And if you're into modifying the trailer, other wheel/tire options (in no wise comprehensive):
https://www.steelsoldiers.com/showthread.php?97026-Tire-wheel-options-for-M105a2
Peashooter put 398/85R20 tires on his M105.
https://www.steelsoldiers.com/showt...Build-Thread&p=1376671&viewfull=1#post1376671
Goldy
Columbus Ohio
I want to thank you all for your responses. I am having a ball with all the veterans who come through my car wash and see the trailer. Some have stories, others just mist up a bit. I will most definitely go through it completely before I trust it. I'm waiting for an old motor pool sgt. to wander in and hear what he has to say.
