New rubber for dogbone
firefox
General
1,844
52
Berkeley CA
What is the procedure for replacing the rubber in the dogbone
on an M54A2, and how complicated is it? Is it just a matter of
getting a rubber insert and pressing it together. The one I have looks
like it was some sort of hot/liquid process, but maybe that was just the original factory process.
And yes, I used the new search but didn't find anything that made
sense to me.
Any suggestions or comments are welcome.
Thanks,
Bruce
Ajax MD
1,437
Mayo, MD
I found the process for inspecting the dogbone bushings/bearings in the TM.
One question- Can the wheel be on the ground when performing this test, or does the axle end need to be on a jack stand?
simp5782
Feo, Fuerte y Formal
9,511
Mason, TN
It can be on the ground. If the truck has been sitting then they will fail the test. The rubber gets very frail. Just weld the safety plate to them. Or replace them one bone at a time as you can afford them. The non usage of rubber is worse than every day use
Ajax MD
1,437
Mayo, MD
Yeah, looking at the costs of the "new and improved" part, I would likely have to do them in pairs.
simp5782
9,511
Mason, TN
The new heavy duty version from eriks? I wore 2 of them out in 6 months. I am not impressed with them as I have 3 dog bones with the heavy duty version and 3 with the rubber inserts the rubber has been in longer and holds up just fine as long as it is used.
https://www.youtube.com/watch?v=XsmTGo6cOo4
Ajax MD
1,437
Mayo, MD
The way I intend to use the truck, the rubber, OEM version should be fine. I'm not a commercial hauler, nor am I an extreme off-roader.
simp5782
9,511
Mason, TN
There are some bad batches of inserts though. Stay away from any of the NewStar versions they were known to fail in minutes
