coachgeo
- 3,398
- 113
- North of Cincy OH
Well, Now that is definitive!Yes, new style has studs old style does not. You also need the new style fan to go with this old style fan will not match the stud placement...
would one with a connection to a machinist be able to cut center out of old fan..... weld in new center and drill new holes to match? Just wondering if 150 bucks was worth this used one off a c7 to have on hand.Yes, new style has studs old style does not. You also need the new style fan to go with this... The old style fan will not match the stud placement...
Well anything is possible with the right tools and talent. Since the plastic fan is molded around the center plate you would have to watch the heat applied...would one with a connection to a machinist be able to cut center out of old fan..... weld in new center and drill new holes to match? Just wondering if 150 bucks was worth this used one off a c7 to have on hand.
I had a friend of mine machine a plate that bolted to the old fan and had new holes for the clutch. No welding needed.would one with a connection to a machinist be able to cut center out of old fan..... weld in new center and drill new holes to match? Just wondering if 150 bucks was worth this used one off a c7 to have on hand.
