GamecockCucv
- 0
- 0
- Columbia, SC
Hello forum, I recently picked up an M1009 that wasn't running. I have spent several weeks of spare time sessions trying to get it going. I changed the oil and filter and figured out how to wire in the two batteries, it was ALL new to me yall. I couldn't get it to fire up so I changed out the glow plugs and she cranked up and ran for about 20 minutes. I couldn't get it into gear because I have a linkage issue or a fluid leak (not sure which). I had somewhere to be, so I shut the truck off.
The next day it wouldn't start at all. Nothing. So I figured the fuel system was losing pressure. I changed the stock fuel filter to a spin on and I replaced the original fuel pump with another mechanical pump (that was a patience tester). I bled the system with compressed air to the line coming off the front of the IP. But still no cranking. I put a gauge on the new fuel filter and I was definitely losing pressure somewhere.
Before I dropped the tank and cleaned it out and cleaned the sending unit I thought I would try some ATF in the block with some gas fumes on a rag. I saw that on youtube and was getting frustrated trying to get it to fire. This is where I'm fearful I screwed something up beyond what I can troubleshoot/repair so I came here. I'm sure I deserve a good tongue lashing. But, when I tried to crank after the ATF adding and gas fumed rag the engine made one good jump and then locked. It won't turn over, it will just try and fail like the engine is locked up. I don't know what has happened and I'm searching, fearful it is bad, bad, bad. I can't even turn the engine over by hand with a socket on the front engine bolt.
Something is seized. Any help is appreciated. I know I've made a newbie mistake, so I can take the lashing too.
