New to site
MJKJ
Sullivan WI
Hi all,
I have this in the new member section to. thanks for the help
I have a question that I hope to be answered. The right rear-rear axle shaft was leaking at the flange and after pulling the shaft the outer bearing has no grease on it but differential oil covering it. Is this correct since this has the central air system with air seals in hub separating the inner and outer bearing. The inner bearing should have grease in it.
I can not get the hub to come off after looking thru the TMs for anything I missed besides removing the nuts. The reason this bugs me is I read a trip posting about a truck having its wheel bearings fail with something about these bearings not being packed with grease during overhaul of the truck. The hubs have not heated up during my drives and no noise while giving the wheel a spin rolls smooth.
Artisan
227
CDA Idaho
I have not done mine yet to advise you properly but I might
look real hard at the TM's and look at the parts exploded view
and make sure you have ALL the right stuff removed so the hub
"SHOULD" come off then support it and go to the backside
WITH THE TIRE ON and kick it and I bet ya it comes off.
I do believe a trick in doing that job is to indeed leave the
wheel attached and use a dolly and pull the wheel and
hub all at the same time...
Do your research and please, BE SAFE.
MJKJ
Sullivan WI
Hi Artisan,
Thanks for response. I have FIELD MAINTENANCEREAR HUBS REPLACEMENT (M939A2) TM 9-2320-272-23-3 work package page 0482 I think its just the air seals holding but not sure.
MJKJ
Sullivan WI
Hi Artisan,
The brake for the wheel is caged. The drum is off.
Equipment Condition
Front wheels chocked. (TM 9-2320-272-10)
Spring brake caged. (TM 9-2320-272-10)
Rear wheel(s) removed. (TM 9-2320-272-10)
Artisan
227
CDA Idaho
Well, Hopefully someone who knows what the heck is going on will
see all our bantering and chime in w/ some real help here soon...
MJKJ
Sullivan WI
Hi Another Ahab,
Thanks for the welcome. I just need to figure this out before putting a real load behind it. I already went thru the trailer with new bearings.
Artisan
227
CDA Idaho
Hmmmm, who is the resident 5Ton Hubmeister?
If we keep bantering a man of knowledge will chime in,
So long as you have done due diligence and read the TM's that is...
Another Ahab
4,549
Alexandria, VA
"Seek and You shall Find,
Knock and the Door will Open"
But nobody ever said anything about how long we might have to wait….
Artisan
227
CDA Idaho
Make sure to search this forum, using the search function, and see if
there are threads from the past relevant to your scenario.
MJKJ
Sullivan WI
I figured out my problem with trying to remove hub from spindle, I had to overcome the air and oil seals in the hub came off. Now I need to check the rest.
