New Trans, still working out the bugs.
980
24
Dover, New Hampshire
Hey everyone, just wanted to let you know that the New trans has been doing great! (refer to thread http://www.steelsoldiers.com/deuce/60303-yet-another-transmission-replacement-thread.html) Just a couple of quick questions:
1. The trans grinds a little bit going into 4th both upshifting and downshifting, but only sometimes. It's not like a harsh grind, more like something is still spinning a little too fast. I just want to make sure it's not a mis-adjusted clutch or anything. Should I be worried?
2. When in first the normal 'whine' is a little higher and louder, like it is taking more effort then needed to move the truck. Only in first, not as much in reverse. I might just be paranoid but is there a reason for that?
I just want to make sure I did everything right, thanks in advance 4 the help!
JDToumanian
15
Phelan, CA
Grinding 4th is a common problem in these transmissions as they wear..... My old transmission didn't do this, the 'new' one does. Just be more patient when shifting 3rd-4th. The synchros are probably a bit worn, you can prolong the life of the trans by matching the speed closer.
I wouldn't worry about the noise in 1st.... there's nothing you can do other than make sure the oil is filled correctly. When I first swapped out transmissions I was conscious of all the different noises the new one made that the old one didn't, but after a while I got used to them and consider it all "normal."
B.T.W. - You should have just continued this conversation in your other thread, rather than start a new one about the same project / problem. A moderator will probably merge them together....
Jon
980
24
Jon[/QUOTE]
Oops! Sorry (another rookie blunder) :doh: should have considerd that.
