New Unimog
cranetruck
75
Meadows of Dan, Virginia
The U20 model.
........According to Mercedes-Benz, the U 20 has been designed for small- to medium-sized local authorities as well as gardening and landscaping contractors. Although it is the smallest Unimog, Mercedes claims that it is just as capable as the larger models, sharing familiar features such as permanent all-wheel drive, single tires front and rear, differential locks, portal axles to maximize ground clearance, coil springs, power take-offs (PTOs), and onboard dual-circuit common hydraulics. Standard equipment also includes an air-conditioned cab.
Power is supplied by the four-cylinder Mercedes-Benz OM904 LA turbocharged diesel engine that powers models in Mercedes Atego and Vario European truck ranges. This version is rated at 147 bhp (110 kW) at 2200 rpm, with maximum torque of 428 lb•ft (580 N•m). The Euro IV-compliant engine uses Mercedes Bluetec selective catalytic reduction technology to control emissions, using a urea additive.
Transmission is provided by an eight-speed gearbox offering maximum speeds of 0.7 to 56 mph (1.1 to 90 km/h) at the rated engine speed of 2200 rpm. Auxiliary drive systems include numbered and color-coded hydraulic connections at the front of the vehicle and a PTO at the front mounting plate.
