newb...with good idea..i think
saveitforsunrise
south ga
im a newb here and i am looking into buying a m1008 from a local mv dealer once i sell my 97 tahoe, the thing that iv been thinking about is a snorkal kit, would it be too much to run a 5 or so inch pipe from the intake down under the cab and up into the bed like an ex stack? im feeling that this would work if there wasnt too much throttal lag, sorry if im wrong about this or anything, im 17 and need something to make it through a few feet of water on a emergency basis, i live on a river and the road floods out every time we get a few foot of rain, and also would a m1008 be a good choice for south ga?
Cucvnut
75
Carver, Oregon
If I was building a snorkel I would go in to the cab or adapt a jeep style that goes out the fender and up the sideof the windshield.
Chief_919
104
Western NC
As someone with some swiftwater rescue experience- planning to drive through flood waters is suicide.
The water is often swift, and will carry your entire vehicle downstream quickly.
The roadways often wash out, and the 3ft ford can become 10ft instantly as you go ahead. You can't see the bottom, and you can't tell.
Obstacles get washed into the roads, and you can't see them. I have seen a truck get stuck in the water during a flood because a brabed wire fence had washed into the roiad, he drove over, and he ended up with barbed wire wrapped around the driveshaft and wheels.
Every year people die because they tried to drive through flood waters. Far, far more end up having to make rescuers risk their life to rescue them because they tried to drive through flood waters.
Don't be one of them.
saveitforsunrise
south ga
its a private road we maintain to our house, its not swift flood waters, its swamp flood waters, its more of wet lands than fast flowing waters like up north
mistaken1
Kansas City, KS
When you drive through water deep enough to cover vents (like axle vents) those things being vented take on water which means after fording you have to change the lubricants that are now contaminated with water.
That or extend all of your vents to the same level as your snorkel (or at least higher than the water level you plan on fording).
