Cowhunter
- 12
- 3
- California
Hello everyone I’m new to the site I have a Mep005a That has a couple of issues one being the batteries drain down unless I disconnect them I have traced it to I believe the alternator if I disconnect it then the drain seems to be gone But it does charge the batteries at a low rate while it is running. The second issue is the hertz meter is not working but using my tester I determine that it is setting at 60 When I isolate the phasers L2 to Lo is 60 L3 to Lo is 60 but L1 to Lo is very erratic it first register 60 then it jumps around and settles in in the 80 8590 range back-and-forth all three of the phases Measures 120 V steady single and when I measure any two I get 208 any comments and maybe this is not a problem I don’t really know if I can get this all sorted out my plan is to use it for back up for my home and have been looking into changing it to 240 single phase but I wanted to get the other issues taken care of before I tackle that
