Thumper580
- 210
- 43
- Virginia
I've searched and still cant seem to find a final answer... Two questions on M998
1. If I want to drain the water separator is the engine running or not? Just Crack the valve and drain till fuel is constant? I don't want to get air in it.....
2. I have no problem getting the fuel filter off and replaced..... QUESTION. Do I simply attach the fuel hose lines, turn the key to ON, and bleed till no air come out? Does the bleed come the drain valve or off the top of the filter assembly?
Sorry for the dumb question but I want to avoid leaving air inside and creating a running problem.
Thank you, much appreciated.
