Newbie needs Deuce help
Fatman2
St, Louis, MO
Newbie…I finally have my truck home, however, I have a few questions and please try not to laugh to much. Where is the power switch I cannot turn on any lights and brake lights do not work; and where is the windshield wiper switch? Thanks
avengeusa
MI USA
the brakes, headlights, turn signals ect are all controlled by the switch to your lower left with 3 levers on it
top lever is off in the up position, second activates the brake lights, 3rd activates headlights, brake lights, to the left the switch operates the blackout lights
the bottom lever to the right is the lock which keeps the top lever from moving
avengeusa
MI USA
wipers, if air operated are located to the lower left of the wheel also, it is a knob, turn counter clockwise to open and begin airflow to the wipers, the speed of the wipers is controlled by the amount of opening in the air valve....
if you need any more info please read the manuals, they are all posted on this site, be sure to check all fluids and all of that stuff, make sure you have air pressure for the brakes as well as brake fluid before you drive, these are pretty big trucks
ps brake fluid can be added into the master cylinder, there is a door in the floor of the truck, on the drivers side
call me if you need more help
734-682-5107
tim
ctmustang
Thomasville-N.C.
Don't mean to be harsh but sounds like a good candidate for the TM's. You mite want to start with a little bit of reading for your safety and of those on the other side of the road. Especially the part about the brakes. Congrats on the truck!
Just my2cents
CTMustang:beer:
DieselBob
15
Arnold Maryland
Checkout TM 9-2320-361-10, page 001200-02. Has a good diagram/picture of the light switch settings. Available in the "Resources" "Technical manual" section.
tm america
24
merrillville in
nice looking m109 you'll love having it check the tms out they will really help you out with important things you need to know .if you try whats in the tm and still are having problems we will talk you through it and someone here will probably have parts if you need something
1,131
The Operator's Manual here on the site (available for free) is your new best friend.
Welcome to the site!
