WalkingToFreedom402
- 1
- 3
- Eastern Nebraska
Hello, I recently purchased a M1009 & have begun tracing wires & reading Technical Manuals.
The previous owner only had the truck for a few months. He claims that the starter 'was acting up' so he replaced it. It hasn't ran since.
There are 2 wires which were clearly burnt up near the terminal block...one comes off of the rear battery negative cable & the other appears to head to the drivers side alternator.
I began by disconnecting & removing the starter to verify that it had a 24 v solenoid which it did. I left the starter unhooked & taped the leads for testing purposes. I installed 2 new batteries & rigged up fuses in case I had a short. I followed a battery diagram that I found on this site. I connected the rear battery positive, then the negative, then the positive on the front battery(which goes to the negative on the rear), then the front battery negative which is grounded to the block/frame. Neither fuse popped but within 15 seconds I saw smoke coming from one of the terminals & quickly disconnected it.
I would love some opinions on what the previous owner may have done incorrectly & any recommendations on which direction that I go with my troubleshooting.
I have spent some time reading posts on this forum...just looking for some guidance.
Thanks in advance.
PS: I should also include that it came with no batteries & that I comfirmed the trucks operation from another previous owner who did state that he had some sort of a drain on the batteries the entire time that he owned it.
Thanks in advance.
