NHC 250 AC compressor bracket help
armyrino
Jacksonville Florida
So I was blessed with a free bracket for my M923A1 with the NHC250 Cummins. It did not however come with any installation instructions. I'm sure I can figure it out but would be much easier and save some time if anyone could send some pics of different installed brackets and compressors on the same type engine. The bracket has no name or make on it. The guy who gave it to me only knew that it was for the NHC 250 Cummins . Any help would be appreciated . Thanks in advance Armyrino.
1,172
How about a picture of what you have.
simp5782
Feo, Fuerte y Formal
9,329
Mason, TN
Not one I have ever seen. There are a few versions but you may see if red dot has their instructions. That is not a Kenway bracket. Most of the time the small and big cam cummins compressor brackets bolt to the part of the engine above the accessory drive. There are two bolt holes that go down and one thru the side towards the motor.
I have the NHC250 bracket available if you are interested in one
M35A2-AZ
384
Tonopah, AZ
I do not think that is a NHC250 mount. Here is a pic of a mount, sorry you can not see the mount very well. It bolts to the two holes on top of the oil pump.
