NHC 250 part identification
162tcat
46
Washington
First, I looked in the TM and I'm not saying it isn't there, but I didn't find it.
This is in the return line on the NHC 250 and I've never seen it on the older PT engines I've worked on. What is it and what's it's purpose?
WillWagner
2,724
Monrovia, Ca.
It's a check valve. Should be a 2 psi valve, sometimes they were put in the outlet line to prevent drainback if there ewas a pump issue someone couldn't figure out. Normally found in the suction line before a fuel pump. I can find a p/n if you like.
162tcat
46
Washington
Thanks for the info, Will. Mine is in the return line from the head between the head and the PT pump/return to tank line. I have an slight air issue I've been trying to find so I'm working my way through the system.
jonesal
Mission Specialist
69
Brookings, SD
The check valve is part of the Fuel Tank Ventilation Kit MWO 9-2320-272-20-6. The pdf for that MWO is out there if you want the particulars on it. The check valve is PN 12301495, 4820-01-317-8227.
Al Jones
