No blinkers
TexF18
36
omaha, ne
So question for the experts. This was all working now it is not. Turn signal blinkers are not working working on either side. Bulbs are good. New turn signal, flasher. Grounds are clean and good. The metal plate on the front plastic housing are installed. All running lights work. What am I missing here?
TexF18
36
omaha, ne
Alright found the issue. A contactor in the master light switch is going bad. When in service lights of too far to the right the flashers dont work. If you pushe the switch to the left everything works normal. Ordering a new light switch
M1165A1
859
The High Country, CO
Make sure to get proper milspec switch and not the look alike Chinese lever version (cover plate screws usually not painted is the telltale) or even worse the push button version.
