I've searched other posts and need help.
I have no power running to the connectors on the air pressure switch. When I jump the two connectors with the 3 post light switch in brake or lights position the brake lights do not work, no power to the connectors. The brake lights where working and now are not. Turn signals work great. I've tried multiple positions on the 3 post light switch with no luck.
Do the wires run up to the turn signal flasher box then to the flasher switch on the steering column then to the 3 post light switch? Trying to figure out where I need to search next.
