No Brakes at all - pedal goes to floor
TXMIDGUFFREY
Lindale, TX
Expert experienced advice please.
'71 M35a2 - brake pedal goes to the floor, no resistance, master cyl is full, no air leaks
Troubleshooting guide leads me to "Air-Hydraulic Cylinder"
I found a rebuild kit at Mike's Motor Pool but it calls it M35A2 2.5 TON AIR PACK REBUILD KIT 8345007
Am I on the right track with this?
gimpyrobb
dumpsterlandingfromorbit!
27,785
750
Cincy Ohio
Make sure to adjust and bleed the brakes first. Have you been in the hubs to verify the wheel cyls are good? If not, its time to take a weekend and do it.
Big Tom
114
Millington md
It all needs a good going over to be safe for shure, go under and pull rubber boot back on master cylinder and see if piston is stuck all the way in.
Big Tom
Kaiser67M715
26
NH
**So, I'm going to add to this, as I lost pedal in my truck this afternoon, If the Moderators feel This should be a separate thread, please move.**
I do still have "brakes" it will hold on an incline, but I'm probably only 1/2" from floor. No Fluid loss(that I can see in reservoir, pumping brakes multiple times did not bring the pedal back up, nor did the fluid level drop) I am also leaning towards an Air Pack failure, but would like a second opinion.
I will also say I did my annual brake inspection 2 or 3 weekends ago, removed hubs, and pulled back all the dust boots, everything that should have been dry was dry. Pedal feel this morning I would say was normal, fluid was at top level mark. Again, just looking for a second opinion, I will be going through the whole system.
davidb56
1,237
Bonners Ferry Idaho
wouldn't you lose fluid if it is a air pack issue? I'd be inclined to give the master cylinder a closer look.
Kaiser67M715
26
NH
my thought was I would lose fluid or all brakes if it was the master...but I guess I'm not 100% sure. I need to find a way to get it home first.
davidb56
1,237
Bonners Ferry Idaho
If the rubber cup on the piston in the master cylinder is scored, fluid will pass by it and you wouldn't lose fluid.
