no fast idle
johnsr
lafayette in
ok so now that it is cold out my m1028 wants some atention from me.........lol. i co to start it first thing in the morning and i will have to crank on it 4 or 5 time to start. (i will crank it for about 10seconds and then turn it off then back on to cycle the glow plugs.) if i do not sit there for about a minut with my foot on the go pedle the truck will stall. it is acting like th fast idle is not working on my truck. any ideas on what is rong?
Warthog
229
OKC, OK
The fast idle circuit needs 12v from the ignition switch, a working thermostat switch on the head, good connectors on the fast idle and cold advance.
It could be any of those things.
Have you looked at the troubleshooting section or the wiring diagram?
johnsr
lafayette in
yes i printed up the wiring diagram (E-5) and was kinda thinking it was the temp switch, bad wire or the fast idle soladiod.
Milbikes
CT
When I had no cold high idle, I found a melted connector on the temperature switch on the rear of the passenger side head. I have heard of others with the same melted connector. What causes that?
johnsr
lafayette in
just tested the wires 12.4v going in to the temp switch and no volts after. so i need to replace the temp switch. is this the same as the civy 6.2l?
1,172
You would be amazed what you can learn from looking at the -20P and simply googling the part number.
Of course, simply following the diagnostic procedure in the -20 would also have told you what you need to know, rather than posting this thread.
Then again, a SEARCH would have shown you a few threads with all the same info including the test info and part number.
http://www.steelsoldiers.com/cucv/48453-fast-idle-temp-switch.html
