No front marker lights with headlights on and high beam indicator always lit
ls1rocker
Texas
Working on a 997 that had a cut headlight harness plug, was able to check continuity and identify the 8 wires to reconnect, but having an issue with no front marker lights while headlights are connected/on, rear markers are fine and blinkers function.
Also the high beam indicator light is staying on while in low beam
Checking grounds and connections, but looking for some pointers
LED side makers, standard brakes, front markers, headlights and blinker switch bulb
frauhansen
573
switzerland
I can't say anything about the side indicator lamps.
But I had the same problem with the HighBeam indicator. I swapped the wiring on the lamps themselves. So I connected one lamp correctly and swapped the high and low beams on the other.
