MrShawn305
- 97
- 28
- El Paso, TX
So I recently purchased an MEP-802a genset and I've run it a few times with no issue. Today, I ran a 8/3 cable to my house breaker panel for future power outages. I started it up to test and it shut down on me three times after 5-10 minutes of running with the "no fuel" light on. The unit has a full tank of fuel which I verified by both the gauge and opening the fuel tank to look inside. I started it up again and enabled the battle short switch just to see if I could see something going on, but after that it ran for several hours without issue. I popped open the control panel and checked connections on the fuel gauge, but they all seemed tight. Anyone ever had an issue like this before? Not sure where I should start checking from here.
