EO2NMCB
- 23
- 18
- DeSoto, MO
84 m1009 cranks fine, it is missing the glow plug control card and will not start. I thought I might get lucky with temp's in the mid 90's that it might start with out the glow plugs. I will order a card this week from front line. Is there any chance that it will start with no control card? I did the checks per the TM at the card plug and all volts and ohms check good. It does have fuel at the lift pump, filter, fuel shut off, and injectors.
thanks again
thanks again
