Barrman
- 1,734
- 113
- Giddings, Texas
I can run the Whistler around town or for runs less than 50 miles at any speed I want and it will idle great at all times. I get on the road and run 2200-2400 rpm for an hour or two and it won't idle when I slow down. I have to go 2 clicks out on the hand throttle to hold 800 rpm. If I keep going, it gets gradually worse and top end power kind of goes away some.
I made a speed run of 130 miles Tuesday. The idle problem started after 40 miles. The last 15 miles of the trip I had trouble holding 45 mph. When we got to where we were going, (hooking onto a grain truck to drag home.) I had to use 3 clicks to keep it running. It surged some and died afer a few minutes. I just turned everything off and worked on tow bar hook ups for the next 30 minutes. It fired right up when I tried it and ran great with perfect idle and no hand throttle.
I have changed out the primary fuel filter twice now. I have not changed out the secondary filters. That will happen on Friday, maybe Saturday.
Besides filters, does anybody have any suggestions?
Thanks.
Thanks.
