No Lights?
Bill W
45
Brooks,Ga
If you still have tail/brake lights then I'd look at the dimmer switch., Check to make sure you have power to it (#16 wire) if so then I'd say the (dimmer) switch is bad.
tjcouch
Tampa, FL
Sorry for the highjack - but you mentioning dash lights just reminded me - anyone know the replacement # for the dash lights bulbs off the top of your head?
1,178
Re: RE: No Lights?
Look in the parts cross reference on the lower left of this page. It's there.
<<<<<<<<<<<<<<<<<<<<<<< Left!!! ( visual aid for Gimmpyrobb ) Left!!!
Bill W
45
Brooks,Ga
Dimmer switch: HI/LO beam switch on the floor. Turn your light switch on to Service Drive and see if you have power going to the dimmer hi/lo switch (#16)
1,178
spentshell said:
I lost my service drive lights this morning any obvious things to check out first ?
Did they work lastnight?
Don't take this wrong but are both levers in the correct position for the headlights to be on? (Is everything but the headlights on?)
emmado22
147
Mid Hudson Valley NY
Make sure your not set to the PARKING lights position on the lever that operates the dash/parking lights. The parking lights position "kills" the headlights.
