No/little fuel to secondary and final filter
w250guy
21
Stamford/vt
So decided I’d give the old girl a little attention and low and behold doesn’t it blow up in my face as usual. Changed the oil and all the filters on it and now I can’t get fuel to the final filter, I have fuel at the primary and very little at the secondary. I could hear it starting to fill but then it stopped. And absolutely nothing at the final filter. So I checked the pump and it shot out a good stream about 5 feet from the pump. I loosened the secondary and primary filter cans and now I have nothing at either of them. Is there a screen or an in-line filter or something I’m missing here? No problems with the truck before this. Any help would be greatly appreciated planned on taking it to the fire department tomorrow but it’s not looking that way now
cattlerepairman
3,276
NORTH (Canada)
How did you get the air out? Just let the in tank pump run for a minute or five to push fuel all the way?
Sent from my SM-G950W using Tapatalk
w250guy
21
Stamford/vt
I ended up having my buddy sit in the cab and run the switch while I cracked the lines from the first fuel filter to the last. Worked fine after that
Floridianson
2,501
Interlachen Fl.
You just needed to open the air bleeder that is between the secondary and final fuel filter. Myself even with when my system has no air or canisters full I still let the in tank pump pump for a short while before hitting the start button.
