Blackhawk2940
- 0
- 1
- Justin, TX
Hey everyone. Although I have been researching this site for some time now, and it's been very helpful, I now need some help. If anyone has some insight for me, or can direct me to a thread that already covers this, it would be much appreciated.
52' M37 that I took over the restore on. Everything is stock so far. Alright, so as it sits, it will start and idle just fine, drive out in 1st gear, still really no issues, but when I shift into 2nd, 3rd, and (if I'm going down a grade) 4th, on the lower half of the throttle, it seems like it's missing and I get a choking/popping almost as if it's running out of gas. But if I baby it, it get it through the lower half of the throttle, it will run better in the upper half of the throttle. On a slight decline, I managed to get it into the upper half in 4th gear, and the most I got out of it was 30-34 mph.
Clean fuel going into carb, rebuilt carb twice, it has the mechanical fuel pump, I have the timing set correctly (4btdc), points are correct (.020), new points and condenser, new plugs, cap is good, no cracks (I have already tried swapping it and the coil with new ones, no change).
So if anyone could point me in the right direction, I'll stop getting so mad at the thing.
Ben
SSG Wagner
Ben
SSG Wagner
