- 3,072
- 1,456
- 113
- Pemberton, N.J.
Does GL no longer show whats is in your closed watchlist? I used to use that as a guide to what items were selling for before bidding on stuff. Maybe that is why they no longer show it?
Yup...Does GL no longer show whats is in your closed watchlist? I used to use that as a guide to what items were selling for before bidding on stuff. Maybe that is why they no longer show it?
OH, It is eBay! Now I understand.The work around I have found is to toss out a base/low bid when the item(s) you are interested in are actually accepting bids and then you can review your bids well after the close of an auction to see what the item(s) truly sold for / so you can see what they are selling for...
I thought that was a good idea, until I did that almost 2 days before close and ended up with a 5 ton. What was a hard one to explain to the wife.The work around I have found is to toss out a base/low bid when the item(s) you are interested in are actually accepting bids and then you can review your bids well after the close of an auction to see what the item(s) truly sold for / so you can see what they are selling for...
Ha ha ha ha ha!I thought that was a good idea, until I did that almost 2 days before close and ended up with a 5 ton. What was a hard one to explain to the wife.
Thats why I said "base/low" bidI thought that was a good idea, until I did that almost 2 days before close and ended up with a 5 ton. What was a hard one to explain to the wife.
