No Parking Brakes 1997 M1078
autolocators
Hi we finally got this truck running but can't get parking brakes. All four corners have lines from parking brake shoes mounting up to frame but nothing on inside of frame rails connecting them. Please look at pics. We did connect the one right front line to a splitter that appears to tie into steering. This just doesnt seem right. (See first two pictures).Any help would be appreciated. We have normal brakes and we hold air but obviously no parking brakes.
Sent from my SM-G928P using Tapatalk
Suprman
670
Stratford/Connecticut
Looks correct to me. Truck is held by spring brakes. When you put the dash valve in park does the truck roll? But you can still step on the brake pedal and stop? Do you have an air leak at your front red gladhand and you blocked it off so you can build air?
Coffey1
493
Gray Court SC
I see the problem right off it's tan.
I would have to look at mine to see where lines go.
If no one is able to help I'll take pictures and send to you. My phone number is 704-534 -4486 shoot me a text and I'll text them back to you. Saturday
autolocators
Truck does roll in Park yes but you can stop with pedal. Yes front gladhand is blocked off and shows good air pressure on gauge on dash.
NDT
6,182
Camp Wood/LC, TX
Does the truck roll with no air pressure in the system? Please post a picture of the rear brake cans or pots or chambers, whatever term you prefer.
Suprman
670
You cannot block off either front gladhand. You must fix the cause of the air leak there. By blocking off the front red gladhand you are inadvertently feeding air into a towing release circuit for your spring brakes.
NDT
6,182
Camp Wood/LC, TX
Your rear brakes are not caged. If the truck won't roll with air drained, the problem is as described in post 12. If it WILL roll with air drained, the rear brake wedges are stuck.
Suprman
670
Ok unblock the front gladhands and you will have parking brakes. It's a dangerous situation you have unintentionally created. The air leak on the front emergency side is usually caused by the check valve behind the bumper.
Rmtaunton
31
Smyrna, ga
First , dump all the air, and get air brakes to engage to see if wedges are stuck if not check switch at bottom of brake handle
Suprman
670
If the brakes work with the treadle (foot pedal) and the spring brakes fully engage when all the air is drained out, then somehow you have air feeding back into the spring brake release system. Or air lines are switched somewhere. Did you replace the check valve behind the front grill?
1,172
Please include your state in your info, it's a site requirement.
Please attach pictures, not link them, it's a site requirement. (use the paperclip)
