Everything was working well on this 87A2C. I removed the toggle type starter switch, headlight switch, on/off power switch, heater switch etc. to repaint the dash. After putting it all back together I have no power to the electric fuel pump. I used a test light on the plug that goes into the pump, no power. At one point when everything was pulled apart I got a spark but think that came from the heater blower switch. Everything is back together and everything works fine from dash lights, gauges, exterior lights, blower etc, just no power to the pump. I've looked at a wiring diagram for an A2 but wonder if the late trucks are a bit different, 4 wires to the starter toggle switch etc. Where does the fuel pump wire come out under the dash and what is it connected to? Any help appreciated
