208007344
- 0
- 1
- Nashville, TN
I have an 86 M1009 which is still a 24v system (or so it seems), it has 2 batteries and a 24V starter that I have rebuilt. However, there is not a resistor bank on the firewall to accomplish the required voltage drop? The problem is that my glowplugs are not getting power, which is when I discovered that there was no reisitor bank - had not looked previous to this as all was well. There is a wire with a fusable link in it that runs from the negative side of the back battery to a two stud terminal strip beside the 12v GP relay on the drivers side firewall. From this terminal strip it runs to one side of the GP relay. I have 12v at the strip and at that side of the relay, but not on the other side of the relay nor to the glow plugs when the wait to start light it on. I was going to replace the relay as I suspect that is the issue, but it does "click" when the cycle is almost complete. Questions - Why would my truck not have the resistor bank, or better yet is there a need for the reisitor bank since I already have 12v coming straight off the back battery to the GP relay? Is it possible that replacing the relay will fix the issue of my GP's not getting power? I seem to remember seeing a NAPA part number for the relay that would work but can not find it again? Help anyone?
Thanks-
Travis
86' M1009 CUCV
Thanks-
Travis
86' M1009 CUCV
