No Service Air?
rwminck
Florence SC.
So, I am putting some MRAP tires and rims and I bought the adapter plate package from Peashooter which included the inflation kit. Well, I went to test the set-up with my new 25' hose and I connected to the service gland, opened the valve and nothing. Tanks are full and the gauge reads 120 psi. So, I figure the valve is bad so I removed it, charge the tanks again, 120 psi and nothing? Emergency side works just fine? Am I missing something, could it be as simple as a blocked line? I mean I am holding the valve in my hand, no air hiss, nothing.
P.S. I can't look at the TM's with my little want to be computer. Thanks for any help!
rwminck
Florence SC.
No I was not pushing on the brakes as they are disassembled and I just flat out didn't know this. Looks like I took apart a bunch of stuff for nothing. I need to get a computer that does not choke on the TM's. Thanks for helping me out.
ke5eua
41
Baton Rouge (Central), LA
It's cool, as far as a big boy computer, I have an old convertible that I run kali linux for my pen testing and she runs just fine. Think pre netbook. Try looking at a lightweight pdf viewer, or if you up to the challenge, ditch windows and go with a linux os (ubuntu, fedora, etc...) to run on it and it will run a little better.
