no start
mogger7
gloucester Va
hey guys got my 1079 from texas to Va. put the batterys in it and when u try to start it the starter engages then disengages engages then disengages . the fan turns a few dagrees each time u here it engage but will not turn enough to start any ideas batterys are not new but I charged each one for an hr or so
thanks
Rich Dunlap
maa45069
71
cincinnati/OH
I would make sure your batteries are 100 percent my friend. Bet they just dont have enough to spin the starter fast enough.
Sent from my SM-G935T using Tapatalk
snowtrac nome
140
western alaska
mine has been doing the same thing I need to order up a starter drive. Also while the starter is out you should inspect the starter ring gear the teeth are huge on them and failure is rare but does happen.
Ronmar
8,140
Port angeles wa
Got a multimeter? First test is the testpoints on the power panel. Voltage between ground and the 12V TP and ground and 24V TP. 12V is hot when batteries are connected, 24V appears when the ignition switch powers up relay K2. With the switch on the testpoints should both be the same as battery voltage between the 12 and 24V battery cables to ground. Around 12.6V and 25.2V respectively if the batts have a reasonable charge. If you are not near these voltages, charge the batteries.
now observe the voltages at the two test points while you try to start it. If one drops significantly, look back thru that circuit.
just troubleshot something similar on my truck last week, turn on switch, warning lights and low air buzzer come on, push start, starter goes clunk and everything goes dark. My 12V was disappearing at the power panel when I hit the starter button, which shut of the 26V being provided by relay K2. Traced it back to a bad connection at the reverse polarity diode module below the airfilter outlet. Cleaned the connections and she started right up.
Good luck.
